Can anyone tell me how to remove the metallic silver plastic trim around the rear door handle in this photo? I don't want to break anything but I want to remove it and refinish it.
if there arent any screws visible on it to take it off you will probably have to remove the whole panel.
Just pull loose from the bottom with a screw driver there are slots. They just pop right off.
Start pulling from the narrower part using your fingers if you can. works for me.
OK thanks guys.
