So i have removed the rear door handles and going to have them all painted black, but how the heck do i get the front ones off, the bolt is right in behind the window arm......is there and easy way....
Ok this is dumb question, but what is RAVE, is it a manual....if so i dont have one... is there not a post on this forum covering removing handles.....sorry for dumb question?????
I thought that removing the front ones were the same as the rear. I have done it a long time ago but actually forgot what I did. How did you get the rear ones off? Do you have any pictures or steps of the process? Thanks in advance.
On the rear i undid them from the inside, took panel off and was easy, the front on the other hand the screw is right behind the window arm, cant get in there to remove....
