The washer jets are a huge PITA. The tube to attach the hose is simply too long and overlaps the edge of the cutout in the metal of the hood making installation of the jets/vent quite difficult (I assume 2007 is the same as 2003-4). I removed the hoses and pushed the jets upwards. For installation I filed the back lower corner of the jets to allow them to 'tip' in more easily.
I'm not quite sure what CPF is referring to with clips that need to be bent back (unless the 07 is different - never laid hand on one in anger yet). The vent has pretty standard round molding clips. To remove, just pry upwards carefully. But please check to make sure this info is still correct. Wouldn't want you busting clips off your expensive vent because I gave you wrong info
