Re: Help please! 2006 L322 HDC and Transmission warning / fault
to check the alternator use a voltmeter, measure the voltage of the battery, without engine running around 12 volt and when engine is running should be around 13.7 volt, if it stays at 12v then alternator is not giving power, hope that helps
