About 2 months ago my ABS pump would run after shutting off the car. So the firstr thing I did was try to replace the relay. That did not make a difference and the ABS pump quit working. So I drove the vehicle for a while with no ABS. One day the brakes completely failed. Pedal to the floor no pressure, etc. The fluid is still present, so it was not air in the system, just a lack of pressure. Now I am trying to get my head around a good testing procedure to determine exactly what should be replaced.
So my first question to anyone with brake experience is:
If you are running the brakes without ABS, is the Accumulator still part of the system? If so, is it possible that that is what failed when the brakes went completely out? Obviously I would like to avoid having to replace the booster, so I am wondering if this problem is still isolated to the ABS and Accumulator?
Any help would be appreciated.
2001 4.6 HSE
2001 4.6 HSE
