Folks,
After dealing with my valve block and compressor I am at ride height in seconds now instead of 10 minutes. I am noticing now that on slightly rough surfaces I get a lot of light clunks and what I would call suspension chatter as things move up and down. To me it sounds like the blown out suspension on a high mileage cab. My truck only has 90k on it so I am sure some things need to be replaced.
I am hoping the kind folks here can help me get this sorted. What parts and in what order should I be investigating/replacing?
RIP Our Friend
Re: Help! my suspension chatter sounds like a worm out taxi cab
Obviously you would need to inspect everything for damage and wear. Inspecting is free and doesn't require any specific order.
Re: Help! my suspension chatter sounds like a worn out taxi cab
I am still getting to know the P38 and I have not done a lot of suspension work. I would like to do it my self so I was hoping for some guidance on common culprits for this issue or where to look first and what to look for.
RIP Our Friend
Search is your friend. Suspension clunks, squeaks, wander etc have been beat to death countless times. Since you have been here over a year you already have RAVE and have most likely read through the front and rear suspension sections so you know what parts connect to what.
