1995 County LWB, 2006 MkIII / L322h
I have a ‘06 HSE with a blown head gasket at 180k miles. I’m sourcing a replacement engine and I’m wondering, with the new engine, what I should do to it prior to installation. Are there any old components that I should not reinstall but replace as well? Just thinking of how much easier some of these things would be with the engine on the bench.
Thanks.
Discussion Starter · #2 ·
The ‘new’ engine has 88k miles.
So, just bump/nudging here:
I'm thinking
1. water pump, thermostat
2. plugs
3. belts and hoses
4. radiator flush
If the 'new' motor has 88k on it, would you replace timing chain or tensioners, etc?
I am not terribly familiar with these engines, but I don't think they suffer from timing chain issues plaguing later (and earlier) models. I would change all gaskets with the engine out: valve covers, output shaft seal, etc. If there are any additional cooling components in the V of the engine (a-la valley pan in M62TUs), I'd replace that as well.
Hopefully others with more experience with the FoMoCo engine can chime in.
