Hi, can anyone help with a little advice on how to lift my drivers door, it's catching slightly and fails to line up with the rest of the body IMG_1841.JPG
1995-2002 Range Rover Classic
this is a result of worn out hinge pin, by design the pin did not ride on bushings thus regular use wears out the pin. the proper way to fix is by replacing the hinge, some owners have been able to dill out pin and use a replacement often a bolt as a new pin.
