Hi,
I would like to install two high-beam headlamp on my RRC 1991, in place of fog lamp. I have the two headlamp, wires, one relay, and i don't want a selector ON/OFF but directly headlamp run automatically with my normal lamps. Can somebody explain me how to install the wiring, best place for good contact? best connection? where install relay?
Thanks a lot.
you mean you want the off road lights to come on with your high beams wn\hen you put them on bright?
mine are wired like that from the p.o.
i will take a look at what they did
1995-2002 Range Rover Classic
use a 30 amp relay, wire as normal. the trigger wire which would normally go to a switch becomes to receive the high beam or low beam signal.
now your off road lamps come on every time you flick your headlamps be low or high beam. simple.
