leftlanetruckin said:
Try to find a NAPA, they sell a fitting that is a schrader valve on top, and a 1/4" airline fitting on the bottom. Install the fittings and air it up.
The fittings are by the equalizers and air fitting they sell for dually's etc.
Martin
Yes, I saw them and thought it's a great idea. But all in all I did not needed them - the Range made it almost all the way home. We were less than 100 miles away so I just called a friend to come and pick me up. Then I took my laptop and cable and went back to the Range.
The initial fault read said:
7 : Vehicle has moved
1 : FR valve stuck closed
Then I turned the compressor manually, went to calibration tab in the software and commanded it to go to normal height which it nicely did for me so I got back home without any further incidents.
Now I need to rebuild valve block (which BTW was already exchanged for a used one by previous owner). Funny thing though, when I tried to read fault codes again after getting home this is what I got:
0 : FL signal incorrect
1 : F8:2_Hidden
2 : FR signal incorrect
3 : F8:8_Hidden
4 : RL signal incorrect
5 : F8:32_Hidden
6 : RR signal incorrect
7 : F8:128_Hidden
0 : Engine speed fault
1 : Vehicle speed fault
2 : Pressure signal constantly high
3 : Pressure signal constantly low
4 : Air supply fault
5 : Air supply leak
6 : Target heights incorrect
0 : Cannot lower FL
1 : Cannot lower FR
2 : Cannot lower RL
3 : Cannot lower RR
4 : FA:16_Hidden
5 : FA:32_Hidden
6 : FA:64_Hidden
7 : FA:128_Hidden
0 : FL valve stuck open
1 : FR valve stuck open
2 : RL valve stuck open
3 : RR valve stuck open
4 : Inlet valve stuck open
5 : Exhaust valve stuck open
6 : FB:64_Hidden
7 : FB:128_Hidden
0 : FL valve stuck closed
2 : RL valve stuck closed
3 : RR valve stuck closed
4 : Inlet valve stuck closed
5 : Exhaust valve stuck closed
6 : FC:64_Hidden
7 : FC:128_Hidden
1 : F8:2_Hidden
3 : F8:8_Hidden
5 : F8:32_Hidden
7 : F8:128_Hidden
5 : Air supply leak
0 : Cannot lower FL
1 : Cannot lower FR
2 : Cannot lower RL
3 : Cannot lower RR
4 : FA:16_Hidden
5 : FA:32_Hidden
6 : FA:64_Hidden
7 : FA:128_Hidden
6 : FB:64_Hidden
7 : FB:128_Hidden
6 : FC:64_Hidden
7 : FC:128_Hidden
That got me thinking a little bit. My only hope is that this whole set of crap is because the car was driving with cable and EAS software connected. We'll see later.
Thans again for any help.
