2006 RR Full size 4.4 206k. I took my truck for a drive yesterday (about 10-12 miles) then parked it in the driveway. About 2 hours later, I went to pull it into the garage and it won't start. It cranks fine, there is plenty of gas, no symptoms of anything before parking it. I checked all of the fuses, swapped out the fuel pump relay, tried starter fluid, disconnected the battery overnight and it still won't start.... I'm at a loss.
Im having the same problem with the same vehicle...... I dont have as many miles but same sytmtoms. Whered you get the relay from????? My next step is to check voltage at relay...
Not claiming it's the sameproblem, but when my fuel pump went on my '05 there were no symptoms leading up to it. Just wouldn't start one day. I installed a BMW X5 pump (same one). and all was good.
I had my mechanic friend come by today and he diagnosed it as the fuel pump. There's power all of the way to the pump itself, but we couldn't hear any noise from the pump itself. Funny thing is that I replaced it about 2 or 3 years ago with cheap part from rockauto.com. He said that's why I'm having to do it again....
