Battery was dead. Now my front end is stuck down. I checked fuses and they all seem to be fine. Tried the steering wheel reset. Has to be something simple. Hard fault codes. Max 35 mph reading on dash.
If the battery was dead, the car has likely been sitting for some time. A leak has caused the front to drop, if the tank isn't full anymore (quite likely it also has a leak), the compressor will have to work hard to fill everything. If it can't do this within ca 10min, the ECU will see this as a fault and trow a code. Could be a height sensor out of range as well. You'll need to get a codereader to read and clear the fault, before attempting again. If you have access to a shop compressor, you can use that to fill the tank and make things a lot easier on the onboard compressor. Still need to search for and fix the leaks though, to avoid this happening again (and getting worse).
Filip
Super Moderator
But if he has an L322, there isn't a Nanocom available for the 2003-1010 model. What car do you have?
