21 - 26 of 26 Posts
You'll need to remove the supercharger to access this pipe FYI, so not sure a standard timing chain job would make it accessible. Although tackling the supercharger does make a lot of sense to throw in.
VelocityAP pulley and tune!
If I were you I would just change the guides and tensioners. A much easier job and the chains are usually not the problem. With 170K on the engine the injectors will be almost impossible to remove with the engine in the car. I would take the engine out to do this job. Just fixing this one right now although this has other problems.
291541
Did that just drop out the bottom? Is that a cab-off job like a Ford Superduty
21 - 26 of 26 Posts
