Is there a welcome section for those that are new to the forum?.
010 santorini black range rover sport supercharged / spice interior.
Thank you all most kindly.
My RRS SC is a little bumpy on uneven roads, should I have the tire pressure adjusted?. It is currently set the way it came from the dealer.
Regards.
its mandatory to always check your air pressure in your tires. You are responsible not the dealer for setting tire pressure. They could have set them high or low but no matter once the vehicle is in your hands its your responsibility. Besides it cuts down on gas usage if you run the tires at the correct psi.
yours should be 38-42
And welcome, if you have questions about your new vehicle see your salesman, not the service writer.
