Heavier fluid for noisy differential?
3166 Views 2 Replies 2 Participants Last post by  thedugger
I have a front differential noise around 35 mph that's slightly annoying. I changed the fluid the other day with the reccomended 75W90 (Lucas). No real change, but I noticed that first thing when cold, the differential is much less noisy.
What are everyone's thoughts on changing with a heavier 80W140 or something similar? While I realize this might cause a nominal reduction in fuel mileage and hp, I would gladly accept that for reducing the noise and putting off any major work...at least temporarily.
Also, what is everyone's favorite diff fluid???
Thanks in advance!!
if it's only around 35mph, I dont think it's the diff, I never heard of a differential noise going away, usually louder with speed.
i can understand if it changes under load but then you have a really worn diff and should look at it, not mask the problem
That's why I think it's a bearing in the diff rather than worn gears, etc.
For starters, I'm have a diff shop open everything up next week, they think off hand it's the pinion bearing first, with the ring and pinion gears second.
It's amazing how many road blocks I have trying to diagnose this. Every shop either shy's away completely, doesn't know anything about diffs/trannys, or just wants to replace everything. They get nervous when the Rover pulls up, but I really don't think there is anything special with the differential setup on these.
