21 - 30 of 30 Posts
So you're trying to remove the dash but can't?
hello romanrob,
I am trying to remove the heater matrix by the way explain by this post but i can t bend the lower part of the dash
Are you saying that it is foiling on the stud at the bottom where you've taken the nut off? If you are then bend it a bit and pull harder. It's only thin plate so will bend back when you put it back together.
I used this method on my 97 HSE but I had a 99 as parts and I could not get this to work. I just cut it with a saws all since it was sold anyway.
Something in 99 up has something else connected, Good Luck
hello every,
Thank's for your contribution to my problem. mine is a 1998. Perhaps something change as xrav22 say... I dont know.
I will try to reduce the stud then bend.
Stop pussy footing around and heave on it. It'll move if you give it enough force.
21 - 30 of 30 Posts
