I need to replace my heater core. I like the idea of replacing the heater blower motor and the resistor "while I'm in there." However, the parts are not cheap and currently work. What is the collective wisdom of the forum on replacing all three, even if some of them work? Thanks in advance.
95 RRC County LWB
The 95 rovers heater is more like the heater assembly in the discovery 1
Other than that I haven’t had the pleasure of working on one of those...,
But if you do replace the heater core
Then I would say yes
Replace everything you can while it’s out ....,
Or not...
It will ultimately be up to you
Have you looked at Atlantic British...
The kits there are not really that expensive
Heat is a really nice part of driveing
I would agree... if you have the dash out, do all you can. The plastic near the windshield breaks if you look at it wrong on many of our 95 RRCs.
