The local Land Rover stealer just quoted me $ 8.50 Each for Heater Core O rings! Anyone quote me the size so I can go to ACE HARDWARE and get the same size for .30 cents? Thanks!!!!!!!
If you had looked before posting you'd have seen it :naughty: .
The information is linked in the o-ring sticky right at the top of the board, click viewtopic.php?p=83932#83932 to go right to Jos post.
Sigi
Buy Viton not some cheesey crap from Ace. Replacing these things is a pain in the ass and you want something with the absolute maximum in chemical and thermal resistance so you don't have to do it again. I'm convinced that if Rover had spec'd Viton to start this wouldn't be such a common known issue.
I tried going thru bunches of o rings and never found the exact size.
I found that the genuine ones were slightly different to those off the shelf, being a little thinner in section, closer to 2mm than 2.5mm.
