My blows have stoped working completely, If i bypass relay 6 & 7 they work.
This issue seems to be an issue with the feed used to energise the relays, i have checked with a multimeter and the 2 connection to energise the relay are positive, I belive 1 should be negative.
Can anyon advise what to check next
I have just tested further and notice when the ignition is switched on 1 of the relay sides goes negative but not enough to active the relay.
Does anyone know which wires or colour are supposed to be negative on the bottom of the fuse box on relay 6&7 so i can test it, this will probs tell me if there a problem with the fuse box?
Hi
As rrtoadhall said inspect your fusebox. This means take out all relays and remove the plastic top cover to inspect the PCB underneath. Disconnect the battery before doing this. You will probably find that the tracks or clips that secure the relay on the PCB for the relays are burned. On the main site there is an excelent guide with pictures on how to repair.
Regards
Jos
