The heating element in the windscreen does not appear to be functioning on either side. There is no visible damage to the glass or the wires. I assume that there is a blown fuse. Does anyone know where this is located? Any other suggestions as to the cause?
Thanks.
Thanks.
The fuse is #47. It did not appear to be blown. I replaced it anyway. It did not correct the problem. Can anyone suggest any other cause for the heating element in the entire windscreen to be non-functional?
stemikel said:
Thanks.
Replaced the screen recently? When mine was replaced they cut through the wires....
