Getting an HVAC error code for Heated windscreen grounds but I can't quite find their location. There is the one connection under the center of the cowl but I assume that is the positive connection. Any help appreciated. 2002 P38.
photos of every connector and ground should be in the ETM in RAVE.
Under all the plenum plastics (the centre bit that always has the foam missing!) right in the centre next to the wiper boss.
+ve are plastic covered connectors under each side plenum plastic
