I have a beautiful 1988 Range Rover with only 98000 miles on it... but a few things are starting to go wrong.... first of all the heat will not shut off & AC won’t go on ... also drivers side door won’t open from inside & the window won’t go all the way up ....any tips???
Pull the driver door card, chances are the interior handle needs lubrication. Window is probably a broken plasic slider on the regulator that stops it from going all the way up or gets caught with something on the way up.
AC could be pressure switches, relays, switch or something else.
