Just back from a bash over to Arnhem and on the way back after I used the wash wipe with my headlights on I could see water jetting onto to one headlight and hear the washer pump running. Quickly got the 'low washer' warning but the pump kept running and the wiper blade on the same headlight was stuck in the vertical position. Pulled the fuse to get me home but haven't had the time to look at it yet.
Anyone seen this before?
Thanks for the steer. Have tried to remove the headlight assembly but the nuts are seized on the posts which are presumably moulded into the headllight surround. Nuts and studs turn togehter! :evil: Expect i will have to cut the nuts off. Anybody else had the same problem and suggest a solution other than splitting the nuts?
Guess why I haven't repaired mine yet...
Nuts rusted to the bolts and they turn together :doh: .
I already bought a new headlight assembly, but haven't found the time to install it yet.
I think I'll have to cut the studs, too.
Sigi
