1 - 10 of 10 Posts
I found these little do dads located between the headlight and the headlight harness on the new parts car. I have no idea what they are or how they affect the headlights any help would be appreciated..
Thanks Scotty
Yes it is HID bulb and ballast
I did after I posted my bad :oops:
So what is the long term affect if any using the system on the Rangi.. (BECM) issues?
Anyone know?
Scotty
hey scotty,
I used to have an HID kit in mine for about 3 years until i converted to the l322 lights. I had no BECM issues. However I've heard that if u use the cheaper HID kits, they might give u a "dip low beam error", due to the 35 watts instead of the 55 watts. I guess it has to do with the flicker harness. Any 1 else have any knowledge of this?
2000_RR said:
hey scotty,
I do have the error for low beam and high beam. You get 1 message only after you lit them up, then you're fine.
I didn't have time to make an assy of electronics to solve the issue.
I tested many HID error free cables that are made for BMW or AUDI but it doesn't work on the Range Rover. BECM logic is different.
Discussion Starter · #8 ·
thanks you guys the little box says 55w and 85w on it..Turbo the A, B. C, and D pillars are covered in the 2000 rangi!
Sorry.. Hey I can send you that plug if you want it no charge. Your in France right :think: That would be intresting..
SCotty.. the reason for the error msg is because that set that you have there is a HI-LO bulb... when our cars use to separate bulbs for hi and low..
I am running the same kit on my truck however just the low and I do not get the error msg..
Its something you live with if you want a little for light coverage on the road.. My recommendations is to adjust the light beam a little lower as the HID kits are bright..
Discussion Starter · #10 ·
I haven't installed them yet, I just removed them from the parts car..
Thank you
1 - 10 of 10 Posts
