Has anyone had issues with their headlight burning out. Mine factory light just burned out again for the third time. Just seems odd to burn out so quickly on a 2016.
2019-2021 Range Rover Sport
Assuming there isn't moisture in your light housing. The other culprit is oil from your hands. When changing a bulb I put on gloves and remove the bulb from the package and install it. It prevents the oils from your hands getting on the bulb and causing it to prematurely burn out.
Just my $.01.
Mine just burnt out. Do you have HID? mine does. I wonder replacing HID bulb is as easy as replacing halogen bulbs.
Factory hid bulb. Dealer is replacing tomorrow along with addressing my squealing brakes again.
