1 - 11 of 11 Posts
Hello!!
Been having cooling issues and found out last night that my head gasket is letting exhaust into my cooling syestem. So, looks like I will be tackling this job... Where is the best place to purchase the full head gasket kit? Or do I need the entire kit? Any advice is greatly appreciated, thank you!!!!!
283881
Take the heads to a machine shop and have them tested and cleaned when you have them off. If any of the valve seals are leaking they can replace them.
Thank you!!
Thanks for the advice!!
I should probably do the kit with the head bolts right?
Maybe you can find an engine, compare prices.
If you are rebuilding the engine you have to do it right. Chains, guides, gaskets, valve adjustment, water pump and suoercharger rebuild
Hard thing was valve adjustment
I did this and was the last time, next time I’ll just swap the engine and done.
You need special tools for timing, too much spare parts, time and money, good luck
Why not try a can of head gasket block seal?
I thought about that but I just replaced the radiator, the heater core, expansion tank, water pump and thermostat. because I think someone had tried that before me. At least that is what I am thinking now... there was this white chalkie stuff in th ecoolign system that clogged up the heater core, I just dont want all that new coolign system to get ruined by adding that stuff in there. I would rather not do the head gaskets eather though:)
I am not rebuilding the engine, it actually runs really good and strong. It is jut the head gasket letting in eshauxt fumes/pressure into the coolign system causing my issues.
Your decision is your decision. You have to think about mileage and the process. You can easily replace timing components and rebuild supercharger while you were there.
It is like gambling. And how many years you are ready to keep this vehicle?
I am not saying do this do that. I saw similar situations owner paid 2 times labor and parts to reach timing chain.
If you are doing the labor yourself, I would do the rebuild as engine removal is either a body off job or major component removal to extract out the front. A used engine could be ready to implode where-as you just rebuilt the one you got and it should be strong. For piece of mind do the timing components also.
Timing tool: https://www.amazon.com/8milelake-Engine-Timing-Jaguar-Rover/dp/B017X8Z8ZS
After you are done I'm sure you could sell the tools onto another user. Head bolts are TTY (Torque to yeild) so should be replaced.
1 - 11 of 11 Posts
