Hi All,
I'm about to embark on doing the head gaskets on my 1992 LSE, I've got a set of the later 10 bolt heads and am going to use the composite gaskets. I was going to use the stretch bolts but don't know what to do regarding the bolt that has a threaded portion for the alternator bracket.......
Apologies but I've tried searching but not very successfully!
When I did my HG I used the ARP studs, which also don't have a provision for mounting the alternator. What I did was just take an angle grinder and cut off that part of the mounting bracket. I haven't had any issues without it.
I did the same job last October. There's an integral nut on the alternator bracket head bolt, but it has to be torqued to 66 lbs. in 3 progressions (like the rest of the head bolts, link below)
If you haven't found it in your research yet, the composite gaskets have 10 holes instead of 14 - just ignore the 4 extra holes, Land Rover determined they were overkill at some point in the early 90's.
280823
Thank you, so just to check you used stretch bolts in all locations except no10 for the alternator mounting bracket and haven’t had any issues?
The alternator bracket bolt is a stretch bolt and has to be replaced with the rest of the head bolts. Its torque spec. is just lower, so I'm guessing that it might be a different metal
I've driven 1000 miles with the new heads + bolts, everything's still good!
