Looking into possible things to check
As soon as 4.4L '03 is started, suspension does its thing, and 5 seconds later chime sounds and HDC Inactive / Air Susp Inactive pops up.
It locks the ride height, and does not articulate suspension for the rest of the trip.
I suspect its ABS sensor or actuator related, is there any way to pull ABS codes without using TestBook? I have OBD2 reader, but that is not enough for ABS.
Battery is good, alt charging, etc.
could be many things, spend the money and have the codes pulled. If it's throwing you weird can bus faults and some steering angle sensor codes get an alignment.
check the brake lamp fuse.. and make sure the brake lights aren't on permanently. I had this when my fuse for the brake lights had blown.
