1 - 1 of 1 Posts
Hi,
I have an 07 TDV8 Vogue. Was out driving in the rain on saturday. I braked two times in a row and suddenly the car chimes "HDC Fault - System unavailable". The yellow brake light (but not ABS) and DSC light lit up in yellow as well. Its pretty much stayed on ever since, occacionally diasappearing and reappearing. When I start the car now the fault is there all the time. I also get two following chimes and "suspensioned lowered", allthough it appears to be in normal ride height.
I have checked the fault codes and they are as follows under. The mechanic who pulled the codes means I have a broken wire or splice somewhere under the right seat (passanger seat in my LHD car). I have also considered it could be a height sensor, but the alllignment in the 4x4 info screen doesnt seem that far of (picture is from car parked on level asfalt)
Could any of these codes point to brake switch sensor, or should I leave that out?
Codes
ATCM-Terrain Response
  • U0401-94 (2E) Invalid data received from engine control module/powertrain control module - Component failure - unexpected operation
    ( on 21-05-2019 12:04:35 at 227619 km )
  • U0402-94 (2E) Invalid data received from transmission control module - Component failure - unexpected operation
  • U0416-94 (2F) Invalid data received from vehicle dynamics control module - Component failure - unexpected operation
    ( on 21-05-2019 12:04:34 at 227619 km )
  • U0403-94 (2E) Invalid data received from transfer case control module - Component failure - unexpected operation
  • U0421-94 (2F) Invalid data received from ride level control module - Component failure - unexpected operation
HVAC-Heat / Cool
  • 0x30 Air quality sensor line fault
TCCM-Transfer Case
  • U0122-87 (2F) Lost communication with vehicle dynamics control module - Bus signal/message failure - missing a message
    ( on 21-05-2019 12:04:46 at 227619 km )
TMC-Traffic Message
  • B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold
Marius
1 - 1 of 1 Posts
