Hi guys my range rover sport tdv6 2006 has the above faults displayed on the dash. My dealer have told me I need a new battery however find this hard to believe. Could a faulty battery cause these messages to be displayed I could well believe the battery causes HDC fault but how would a faulty battery be the cause of not being able to select low range gearbox. Any help would be much appreciated. Getting really frustrated with this car
When you reaccess this thread--scroll down to the box "Similar Threads" and check it out.
Do you think the dealer would tell you a battery if that wasn't the problem? Would you rather they told you that the control module for the differential has a short and needs replaced which requires removal of body to access top of transfer case wiring which will be a grand Total of $3765 dollars?
Or hey your battery needs replaced and is causing fault messages
