Hi all,
ive got a 2006 TDV6, which mechanically is sound as far as I know.
However I keep getting an electronic fault which cuts the power to the engine until I turn it off and on again. I can now recreate this fault by balancing the speed at the higher range of the gear just before the vehicle changes, it feels sluggish then I get all the errors.
Is it worth getting an OBD reader?
If I go into the self diagnostics tool I get the following errors;
30-76
30-71
0B-41 (I think this one is the satnav error, apparently it's a pain to permanently fix)
From reading a few people said it was the battery, I've changed it and still have the same issue.
Thanks in advance!
Discussion Starter #2
Also, I don't believe it's a suspension issue as I used it off-road the other day in some questionable conditions and it was great.
I highly recommend the GAP diagnostic tool. Well worth the $$$
