I just replaced the transmission fluid ,pan and the connector. After about three days i see the hdc fault message then the suspension lowering and trans fault limiting it to 1 gear. i pulled the codes u0126 ,u0167 and i cleared it then i got u0167,u0126,u0121,p0504,u0155. I replaced the Battery and the stoplight switch. it also seems that the codes don't show up unless the truck is warm. The last set of codes i got was u0167,u0126,u0121,p0504,u0155,u0073,u0151,u0101. Does anyone know what i am looking at here? I am totally lost. The truck has 144000 miles on it.
You've lost comms with just about all of your individual control modules ABS, IPC, TMS, Active Restaints, steering angle and your high speed comm bus E negative wire has gone high. It's obviously some kind of a wiring issue. Did you knick a wire replacing the transmission sleeve, or maybe push one of the connector pins out?
it's possible but the connector came out real easy. i didn't need any tools to take it off. everything came out and went back together with out any issue. i was thinking about taking the connector back out and spraying it down both ends with electronic contact cleaner.
I would pull the connector, clean, inspect, treat with electrical spray and go from there.
a little bit of dirt in the connector can cause problems.
i replaced the battery and added a second battery and reset everything. i cleaned off the the transmission plug and reseated it. Everything worked for about three weeks and the codes restarted again. I picked up a icarsoft lr V.20 and it has issues connecting to the car. my other reader has the same issue.
