Right. Bought the L322 on monday, knowing it had this fault. Was cheap enough!
Dash displays HDC inactive and Air suspension inactive on startup. There is also a beep from somewhere. Might be dash. Ive rebuilt the air compressor with a new piston ring etc as i thought hey ho it will need it anyway. There are no lights on for height adjustment. The back end is not on the bump stops, cant see the front but doesnt look too low. I ran my Snap On Verus on it. Can see all systems except Air Suspension. I found an Error code in another module which said Air Suspension Can Error. Am i looking at a broken wire somewhere? Ive checked all fuses. I have ordered another relay for the sake of £8 or so. Hoping you guys can point me in the right direction! Dont suppose there is anyone in the North Cambs area or Norfolk who has proper landy diagnostics to check its not my Snap On Verus playing up?
Hi, funnily enough I have the same problems I'm not sure it is regarding issue with Steering wheel angle sensor because my diagnostics always flag up issue relating to this however I do lock to lock on the steering it clears but as soon I turn my ignition off the fault appears again - so I am in the same boat as you.
