Ok so I went to replace a burned out dip beam on the drivers side of the car, I purchased a Sylvania 9005 I know thats what it takes because I replaced the other side last month 65 watt. I came home removed the rubber cover and presto the light is really different, all wires are the same color as the passager side. It has what I would call a pretty standard plug for the 9005 type bulb with a yellow and a blk wire there are no splices. The drivers side light has a blk ground wire to the fixture and a yellow wire to the back of the bulb which is held in by a spring clip. So the question is which light do I match, which is correct ?
Scotty
Scotty
