I've never been so accustomed to seeing a check engine light as I have with my 2004 Rover :neutral: I'm currently throwing a P1450 Evap code. AutoZone couldn't tell me anything other than the code and I can't find anyone reporting a P1450 using search. I'm guessing it's related to a leak in the evap system. Gas cap seems like the obvious culprit. Cap is relatively new, but I checked it over anyway and it didn't appear loose. Nonetheless I removed and re-tightened
Anything else I can check over?
It is not a fault for a leak, its for the electrical circuit of the DMTL pump(what checks for a leak in the system)
This is generally caused by the pump itself, but full diagnostic equipment would be needed to verify it is not a wiring issue. The pump is pretty easy to replace, located behind the wheel liner of the right rear wheel.
Thank you very much!
Too bad it's not as easy as the evaporative (I have to spell it out because this POS spell check keeps changing it to evap) system fault I had many months ago.
All I had to do was spray some WD-40 into the evaporative system valve that hangs on the front of the engine, and it's been fine since. It was sticking, and giving me a control circuit fault. Can't recall the exact fault code.
