Hoping someone can point me in a direction to get me started. New distributor installed. Replaced amp module. Smooth idle but it takes 3 cranks to get her going. ‘94 with a 3.9. Any ideas? Thanks!
I made the wiring harness, have to be careful on the routing. Mine would not start if the harness I made was anywhere near the backside of alternator. Of course...I should have used shielded wire. No issues with it for a few years now. Can't remember the State side company I ordered the connectors from...
Does everyone agree with narrowing this down to the IAM again? Is it possible to keep cooking these like this? Seems like they should last a few trips and not throw an immediate fit. What would cook these so quickly?
I’m also suspecting the fuel temp sensor here. I haven’t tested it yet though.
I really want to (pretend to) trust this truck. What else should I be checking to cure this?
Amplifier module should be good for at least a 100 thousand miles, mine has. Have you checked your coil? Fuel temp would have nothing to do with poor spark. Have you set the distributor up properly?. Leads and rotor arm, simple things but can cause your issues.
When you say rebuilt, what was done? Is it 3 pin or two on the amplifier? There are only 4 things that cause no spark, amplifier, coil, leads and plugs. Are the wires from the distributor in good condition? Is your battery good?
Been checking and diagnosing. Finally got a code 15 - fuel thermistor. Is that the fuel temp sensor? Is that what’s located in the fuel rail on the front passenger side? Thanks!
My 95 fuel temp sensor is on the drivers, left, side of the fuel rail by the TPS. Only thing on the right hand side is the Schraeder valve to test fuel pressure.
