My 2018 Range Rover Sport developed a problem wherein the navigation / music / climate touchscreen became unresponsive. The music volume knob also stopped working. Turning the car on and off did not fix the problem.
I looked all over the place online for a combination of button presses that would restart the screen but found nothing (e.g. on the Tesla you press and hold the two steering wheel scroll wheels for 8 seconds, and the nav reboots).
I decided the pull fuses, and the guide describing the fuses was a little ambiguous. I was successful with my second attempt: fuse 51 access via the right side of the rear storage compartment (the trunk). I popped open the side wall of the trunk area, used finger strength to remove fuse 51, saw the screen go dead, and then reinserted the fuse. The system rebooted and worked perfectly.
Hope this helps others with this issue!
