2013-2015 Range Rover Sport
I’m trying to sort some electrical issues my 92 SWB may be having and I’m looking to see if anyone has a list as to where all the grounds are located through the vehicle.
As these rigs are over 2 decades, everything electrical can be suspect. A buddy mentioned his fuel pump issues turned out to be related to the wiring harness connector to the pump assembly. Chasing electrical issues is like chasing the POD.
As for grounds, do you have a copy of RAVE with the ETM?
I have RAVE but unsure what the ETM is.
I know of two grounds...
One in the front from motor to the coil holder
The second at the back of the motor
Drivers side from the head to the hood
It’s the wide braded copper cables
Thanks! Those are clean, good and test well. How about interior? I’ve found 3 under the driver’s seat.
There is one in the drivers side rear
Wheel well it is for the fuel pump
