Hi all, I have just picked up my 1996 P38 and I cannot get my truck into gear, when I push on the brake and try to select gears, I get nothing no noise no movement to indicate change of gear, nothing. When I try to place the lever back into park I have a noise from the transmission area that starts quickly, almost like when trying to shove a manual vehicle into gear without the clutch, then slowly winds down, what could be the cause of this? A little background information the car ran and drove until the person I picked it up from parked it almost a year and a half ago.
Super Moderator
Check there is no fuse in position 11. Inserting a fuse there puts the transfer case in neutral to allow the car to be towed.
Yes I had to have it towed to my place and I pulled out the fuse, and I don't get the transfer neutral warning any more
have you tried cycling through hi and low range to check if the case is stuck?
