Today i took my RRS 4.2l SC to a garage for the water pump/thermostat change, i saw the mechanician greasing the pump gasket and edges.
After he started the car and in a couple of minutes i saw grease flowing through the expansion tank.
Is it possible that the grease affects the engine block or the radiatiors/hoses ?
A bit of an exaggeration don;t you think? 8-|=
There is no way a thin coating of grease/sealant on a gasket is going to result in grease "flowing" through the expansion tank. You may see a tiny bit of sheen much like the way a single drop of oil spreads on wet asphalt. It will in no way impact your cooling system or block.
No exaggeration, the grease the guy used was a bearings grease same as the picture below, the engine overheated after i started it and the coolant didnt flow back to the expansion tank with 115c which means that the thermostat didnt open with such high degree, but once i opened the expanstion tank i saw grease flowing back to the tank.
He would have needed to fill the pump and hoses up with a gallon of grease for it to "flow" into tank after removing the cap.
If you would like to tell us the complete story on why it was getting a pump and thermostat in the first place and what happened prior to you blaming a mechanic for filling your pump up with grease we may be able to actually help.
I will break out my crystal ball for a moment.... I am seeing that it may have had overheating problems for a few weeks but nothing major and then it finally got really hot so you took it to a shop and had them change out some parts but there's still a major problem that was there before you took it in
Well I suggest you take it back to the mechanic and voice your concerns. If you aren't exaggerating then we aren't getting the full story.
Is it possible that he did not burp the cooling system? Also, there is a difference between the engine getting hot and overheating- two very different scenarios.
