1 - 10 of 10 Posts
2016-2018 Range Rover Sport
Hi All,
picking up the 2016 range rover sport v8 supercharged autobiography (mariano black) pkg.cpo has everything I think. 34k miles tomorrow .
Came with a 6yr / 100k warranty till 10-15-2021 from dealer . $59k sound good here? they did new brakes + rotors all around / 2 new rear tires
Is there anything here on this rig I should know upfront. any do's or dont's . First time owner here.
ps ,when I get this baby home (oil change) every time I get a car,first thing peace of mind.
Sounds like a good deal. The prices have really dropped since last year when I purchased my 2016 v8 dynamic for ~$64k. I absolutely love this vehicle. Especially when I hit the gas and hear the roar of the engine! Enjoy.
Hi there, maverick.
I think you received a fair deal. You will love the new rig. I would suggest doing an oil change every 4000-5000 miles. I would also check the battery and consider replacing it if it is the original one.
Enjoy.
Steve
This RRSA went for sale 3-1-19 for same miles 34k $75.9k .then they just chopped the price down and down with no bites here, then july 1st.
65,9k -63k- 62.2- 59,9 .I was watching them Bam $59k I pounced on it( Mariana Black / ivory interior with 22" Dubs
2016 RR Sport SC Dynamic
Congrats on the new ride! 2016 is a nice vintage.
Discussion Starter · #6 ·
Hmm! Certified pre-owned by who? A mouse . When I got my RR home I took the engine cover off and found the makings of a mouse nest. he ate the foam under the plastic cover to make the condo. Eviction notice served
that's just odd. they didn't even look. wow.
Nice! I think you got a fair deal and you'll love the rig. If it's been sitting that long the mouse probably moved in after they'd done the CPO process and they never looked at it again.
Discussion Starter · #9 ·
I got and extended warranty added on 4 years / 85,000 miles .0 deductible anywhere for warranty work $2863
in service date 10-15-2015 takes me to 10-15-2025 /85k. only drive about 6-7k a year. i'm at 35k now
I got the top of the line coverage premium pkg. this even included shocks and struts.
When I did the oil change the protector plate had never been removed under the engine to access the drain plug
I guess the dealer does the suction method through the fill cap. sand and leaves on top , 15mm bolts could not be
removed with a socket wrench. had to use the airgun (.the suction pump cost $97 on Amazon) 8.5qts Castrol 5-20
2 - new K&N air filters added , had to vacuum out the cambers full of Christmas tree pine needles.
the Stealership sprayed some greasie stuff under the hood on the black parts to make it shine had to wipe it all
off. The back 5 interior windows in back were never cleaned in the detailing process . spare tire had 25psi in it,not 60 psi I will go through this RR and bring it up to par . I like a nice fresh vehicle that I will service here on (y)
Hope this helps others looking to buy.
Discussion Starter · #10 ·
So when you do the oil change get the AC Delco oil filter real good quality ACD# PF659 (amazon $13.97)
When I checked the oil guage it said overfilled (wtf) 8 liters
1 - 10 of 10 Posts
