Strange question but hopefully someone knows a good answer.
I am looking for a place to install a PA speaker (100Watt) in the front end of the car. I was thinking behind the grill area but the speaker is heavy about 15 pounds and I can't find a good way to mount it there, there isn't anything to firm to screw it too behind the grill. The only other spot I really saw that worked was in the lower portion of the front end near the bottom air dam. I am worried however that anywhere upfront might block air flow which could cause overheating. The speaker is about 5" X 5" and about 3" in depth. Any other suggestions would be appriciated, but as I said it is very heavy and also I want it to have a pretty clear view of the road so that the sound is not distored too much.
Some sort of metal bar bracket should suffice.
You're not likely to block air flow that much.
