Good afternoon, RR forum folks! I hope you are all well! Can anyone recommend a good independent RR shop in Massachusetts for me to get my timing chain, guides, and tensioners done? Don't want to go to the dealership! Thanks so much!
Just in case you missed it in your other thread, make sure your mechanic/shop uses the redesigned "2013" type guides and tensioners. The guides should have steel pads embedded into the softer aluminum where the tensioner makes contact. GL with your Rangey.
Hi, SaturnV. Thank you for that info. Yeah, I did a separate post so it wouldn't get lost in my previous post. I'll keep ya posted! Thanks for your help!!!
