Can anyone identify the Solenoid associated with “TCM Transmission - Pressure Line Solenoid 4 : General Fault” Fault Code?.
My TD6 has recently experienced the “Trans. Failsafe Prog.” Limp home mode and when I read the stored Transmission faults using the GAP IID BT tool, I see the Pressure Line Solenoid 4 General Fault.
I have contacted GAP for furthe4 clarification, and received the following response....
Unfortunately, there is no correlation between the shop manual solenoid letters and the solenoid numbers from LR database. Since documentation is very limited.
Suggest contacting a transmission specialist for advice on these earlier GM units.
We cannot reverse engineer the transmission ECU to see which solenoid links with the fault. Our data is taken directly from Land Rover database and this is what the T4 would display. We have no way of finding out additional info except if documentation from LR or GM exist and so far, I haven't been able to find it on LR tech website.
They have suggested that these may have been used in BMWs
Has anyone else experienced this Fault? and managed to identify which Solenoid is associated with the Fault?.
