Removed the glovebox and trim tonight. Four screws on the bottom and 4 or 6 at the top. Removed the two screws that hold the lock. What is the trick to removing the lock? (I am trying to remove the lock so I can get closer to replacing my orings....) Do I need to remove the fake wood trim? Does the trim just pop off or are there screws holding this in place? Tried to pop it off but was afraid of cracking it. As always, your help is appreciated.
Real goal is two fold, keep the carpet dry on the right side. Pretty sure it is coolant. All I know is the truck is damp on the right side and the paper towels turn yellow/green which is the color of my coolant. Second goal is to stop filling the coolant because it is leaking into the front foot well
