I've just repaired my rocker cover gaskets (and restored the rocker covers) and someone has taken this apart before and not put the bolts back. I am missing all the bolts for the fuel rail and injector wiring and couldn't find in the rave what the bolt size is. An M5 is too small and M6 too big so I assume they must be imperial? Am also worried to run the engine without these bolts and they're probably used for grounding.
Yep, standard M6.
I don't think the bolts are required for grounding. Injectors each have their own wires, and all sensors ground through the loom.
