Hello everyone
I've just registered but have been reading the forum for a while now, so I'll take this opportunity to say thanks for all the help/tips I've picked up along the way.
I've a problem with my 1996 4.6 auto being unable to select Low. It is at the H gate which I cannot seem to cross the centre towards the Low gears. The high box works as it should, but when I stop, select neutral (dash indicating N) then try to slide the lever across (while lifting the button all the way up) I can only get to about half way.
I've put fuse 11 (I think it was 11) in and the dash indicated the transfer box was in neutral, then it goes back to high box when I remove the fuse so I'd guess the transfer box motor was operational. Is there anything in the gear selector part which can prevent this? I have never selected Low before.
Thank you.
Thank you.
