I've had this range rover for a month now and it just developed a very strange issue, I first noticed it when I pulled the parking brake and the fuel door popped open, then I opened my door and it actuated again, now when ever I pull the parking brake or close and sometimes open ANY door on the car the gas door release is triggered, anyone heard of this before or what to do?
I don't have any problems now but after I switched my heater orings I decided to clean the passenger front carpet with detergent and water and my locks started going up and down, randomly . I lifted the carpet and let it dry for a week and locks are fine again. Check and make sure your connections are clean and look under rug to see if any moisture, or any loose grounds by the
computer.
Good luck
I pulled the switch outta the dash, and it stopped, stuck it right back in and it hasn't done it since, hopefully the demon moved on :)
