Discussion Starter · #2 ·
From what i can see it should be connector c112 on the becm, white light green wire.
I have put a multimeter on
Negative probe on wire white light green wire in connector c112
Positive probe on the fuse box positive.
I get a reading of about 2.5v and it climbs slowly to about 3v.
Where do i go from here?
It appears the becm is not giving a negative feed to relays 6 & 7.
I have checked the negative ignition feed into the becm and that appears fine. BUT when i check the output to the relay from the becm connector c112 pin 8 i get 3 volts - This is causing my blowers not to work
