Hi guys, I have a 2004 hse with 65k on it. I'm having a problem and any help would be great!!!! The truck will start and run great with no codes appearing, then out of the blue , I'll go and start it,and it will run for 3 seconds then fuse#31(5 amp) will pop, and dead in the water.....if I try to turn the key nothing happens ,no turn over,nothing!!! Then I'll change fuse #31 and only if I remove the fuse,marked computer control (30 amp)and put it back in (which is not popped )and turn the key it will start and run fine for a little, Only if I remove and and put back in the fuse mark computer control ( which is not blown) and Change fuse#31 ( which is blown) will it start.
Now another problem...... While I'm driving the truck goes dead,and I need to go through the whole process like before in order to get it to start!!!!
This is getting dangerous !!!
I'd be more concerned with your sticky key board and all those ridiculous exclamation points.
